hj2
5 sign-ins First like given First reply posted
I'm using a DEMO BGT60TR13C board with Raspberry Pi 4 and receiving data on all 3 receivers, but Rx1 data is getting clipped with all the Chirps for a few sampling points, why is this happening? Please see the data below and the configuration. I have no problem with Rx2 & Rx3 receivers. Thank you!
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @hj2,
The starting samples are skipped to avoid leakage. The lower frequency bins (lower ranges) have some leakage offset since the Tx-Rx coupling kicks in. These effects can be mitigated with compensation algorithms. The SDK demo examples don't use the compensation algorithms So, the lower range is omitted from processing, in order to use a simple program to demonstrate the working. This is the reason why you may notice some missing samples.
Pugitha.
Pugitha_N
Hello @hj2,
At the moment, we are looking into the issue and will inform you of any updates promptly.
Pugitha
Pugitha_N
Hello @hj2,
Pugitha.
