I have a question about Range and Angle Measurement of Radar Fusion GUI.
Please let me know why Radar Sensor Setting doesn't change between Max range 1m and Max range 6m.
Please see the following image;
I think that it's better to change the setting of sample per charp and sampling bandwidth under short range mode like Max range is 1m.
Please advise.
Regards, Shoko
Radar Sensor
Hi @shoko_s ,
Regarding the issue that you mentioned, the bug has been confirmed and reported. Thanks for pointing it out ! It will be corrected in the upcoming version of the Fusion GUI.
Deepa
Hi @shoko_s ,
We have noticed that the parameters are not changing at our side too. We're looking into this and will soon get back to you regarding the same !
Deepa
Hi @shoko_s ,
Deepa
Hello Deepa,
Thank you for your information.
Please let me know when is the release date for next version of Fusion GUI.
Regards, Shoko
Hi @shoko_s ,
It's still under development and the release date hasn't been finalized. Please look out for the new version. You'll be able to see it in the Infineon Developer Center once it's released !
Deepa
Hello Deepa,
Thanks for your reply.
Noted on this.
Regards, Shoko
