Radar GUI 2.b.1 FW 1.1.7
BGT60LTR11AIP v2.2 03-2020
"Range Doppler View" in "Windows" dropdown can be seen when not connected
When connected to the device, "Range Doppler View" is no longer in drop down list.
"file:///C:/Infineon/Tools/Radar%20GUI/2.8.1.202110151545/plugins/com.ifx.tb.tool.radargui.rcp_2.8.1/... section 4.2 shows an example of a "Range Doppler View" under the 60GHz section.
Is there a range doppler view? How do I get there?
Under "Settings" the "User mode" is set to "Expert"
The major use case of BGT60LTR11AIP is for motion detection and direction of motion detection. It has 1 TX and 1 RX broad beam antenna that does not give much accurate details on angle and range. Hence the range doppler view is not supported by the BGT60LTR11AIP sensor.
The BGT60TR13C has 1 TX and 3 RX antennas, that enables tracking and gives details on the angle and distance of the object. Range Doppler View is supported for BGT60TR13C under the 60GHz sensors.
AliAsgar
AliAsgar
