Radar sensor Forum Discussions
johanvf
First question asked Welcome!
It seems that currently the radar baseboard MCU7 is only available as a kit together with the BGT60TR13C or BGT60LTR11AiP radar sensor shields through distributors. On the other hand, the BGT60ATR24C sensor shield (SHIELD_60ATR24ES_01) that is available through distributors does not come with the MCU7 base board. Is it possible to order the MCU7 baseboard separately for use together with this sensor shield?
HoneyDhandhukia
25 likes received First comment on blog First question asked
Hello @johanvf ,
Unfortunately, the distributors do not have them stocked, but there maybe an alternate option for you to work around as in , you may order the “DEMO BGT60LTR11AIP” (SP005422969) which contains this 60 GHz baseboard to continue your project.
Hope this helps!
Honey
