huzaifa666
First question asked Welcome!
I am changing no. of samples per chirps while extracting raw data from position2go using MATLAB but it is not doing so in actual it always takes reading with default parameters. kindly help me in changing that
Yaran_W
250 replies posted 100 solutions authored 25 likes received
Hi huzaifa666,
Have you saved the GUI settings? Or modify the code configuration, which needs to be rebuilt before it will take effect.
Save (FLASH) and Clear (FLASH) control buttons operations require password authentication every time the
Radar GUI is started. Once erased or overwritten, initial Flash calibration data is lost with no possibility to
back up.
if user changes the “Samples per chirp (Ns)” value in the valid range of [32 to 256], the truth table in Table 5
must be considered to guarantee “Calibration Valid” status.
There is a detailed operation introduction in this link:
https://www.infineon.com/dgdl/Infineon-P2G_Software_User_Manual-UserManual-v01_02-EN.pdf?fileId=5546...
Above, I hope it can help you.
BR
Yaran
Yaran_W
Hi huzaifa666,
back up.
BR
Yaran
