- Email to a Friend
Can I use "Demo Position2Go" in an indoor environment or it will be useless? What are the other options? Note that I want to track multiple human targets within a range of 5 meters.
Regards.
- position2go
- Email to a Friend
Hi @MalekMallah ,
Position2Go will work in indoor environments as well but using it depends highly on what exactly you are trying to measure whether it's distance, velocity or just presence. Also, we would suggest you use one of the newer boards such as Distance2GoL for that matter as position2Go is soon to be discontinued as stated in : https://community.infineon.com/t5/Radar-sensor/Discontinued-Products-XENSIV-Radar-mmWave-24GHz-DEMO-... .
You can also have a look on the selection guide which details on the different available options of the boards and where all you can use them : https://www.infineon.com/dgdl/Infineon-SensorSelectionGuide-ProductSelectionGuide-v01_00-EN.pdf?file... .
Deepa
- Email to a Friend
Hi @MalekMallah ,
Deepa
