jeongeun
First reply posted First like given First question asked
Hello everyone,
I want to know the meaning of magnitude [dB] in the frequency domain in the Radar GUI.
The meaning of "dB" is relative. I want to know what 0 dB means.
Thank you very much!
George_T
50 likes received First question asked 250 replies posted
Hi @jeongeun,
The magnitude in the Frequency Domain plot is the magnitude of the FFT of the raw Time Domain data of the radar (ADC normalized) as per the FFT Configuration in the Frequency Domain Settings.
George
George_T
Hi @jeongeun,
Could you please let us know which board are you referring to?
Thanks and regards
George
George_T
Hi @jeongeun,
If you are referring to Distance2Go board, the FFT magnitude value is converted to dB with reference to the lowest value for the range threshold. The lowest value for the range threshold is 1 and 0 dB corresponds to magnitude value of 1.
Thanks and regards
George
jeongeun
Thank you for your reply.
That's right. I'm referring to the Distance2go board.
When it is 0dB, the magnitude value is 1, what is the unit?
George_T
Hi @jeongeun,
George
