I have MM5D91E00 to evaluate BGT60TR13C and would like to use it with Radar Fusion GUI, but it is not being detected. Is it possible to use MM5D91E00 with Radar Fusion GUI, and if so, can you help me through the process? Thanks!
Radar Sensor
Hello @j_b ,
The module you are using is compatible with Presence detection config tool, available at: https://www.infineon.com/cms/en/applications/solutions/sensor-solutions/presence-detection/?tab=~%27..., please install the same and do let us know if you are facing the same issue or not. Radar Fusion GUI only supports the Infineon 60GHz Demo boards
Hope this helps!
Honey
Hello @j_b ,
Hope this helps!
Honey
Thank you for your help! I had read about this tool in the BGT60TR13C System On Module User Guide but could not find it, your link was very helpful.
