Beatfrequency
5 sign-ins First reply posted First like given
I have tested DEMO BGT60TR13C and wish to proceed and integrating it in a custom design.
I have a few questions,
  • How do I access registers without "stratula" library?
  • What kind of SPI messages do I have to send to configure any registers?
  • How does the FSM behave when the low level registers are configured directly?
Thank you.
Siddharth_H
250 replies posted 100 solutions authored 50 likes received
Hi @Beatfrequency ,
1) You can directly access registers through SPI communication.
2) This is how write operation of  SPI is for this device.
You can go through  5.6: SPI Functionality section of the datasheet for more.
3)  The low level registers are always configured directly, even the demo board does the same. If you configure the device via SPI i.e. directly writing into register, the device behaves the same.
Siddharth.
Siddharth_H
Hi @Beatfrequency ,
Siddharth.
Beatfrequency
Hi Siddharth,
Thanks for your reply.
I only have access to the following registers. Is there a document about other registers?
Siddharth_H
Hello @Beatfrequency ,
The full information about all registers is available in the Full Datasheet. If you wish to have the Full Datasheet, please share me your email address  over the direct message and we will work on sending the document to you.
Siddharth.
