Hi there!
I'd like to know the input capacitance of BGT24MTR11.
Actually, I'm trying to make PLL Block for operating BGT24MTR11, so it's necessary to design Loop filter.
Could you let me know input capacitance of BGT24MTR11(Especially, VCO input Capacitance)
I'll wait your help. thank you
Hello @iiillliili ,
For BGT24LTR11, please refer to the user guide: https://www.infineon.com/dgdl/Infineon-AN472_BGT24LTR11N16_users_guide-ApplicationNotes-v01_05-EN.pd... Section 3 Evaluation board, it includes the schematic diagram with all the capacitance value, and https://www.infineon.com/dgdl/Infineon-BGT24LTR11N16-DataSheet-v01_03-EN.pdf?fileId=5546d4625696ed76...
BGT24MTR11 is used in implementing board Demo Distance2Go, the radar techniques used on the board are Continuous Wave (CW/Doppler) radar for velocity estimation and FMCW for distance measurements. While, BGT24LTR11 focuses on Pulsed Doppler implementation. You can read more on both at BGT24MTR11 and BGT24LTR11
Hope this helps!
Honey
Hello @iiillliili ,
Please confirm the product you are referring to, is it BGT24MTR11 or BGT24LTR11?
Assuming it is BGT24MTR11, here is the reply:
Please refer to the figure attached for capacitance value, please refer to the https://www.infineon.com/dgdl/Infineon-BGT24MTR11-DS-v03_01-EN.pdf?fileId=db3a304339dcf4b10139def491... for further information
Also refer to the application note, section 3.6 Prescaler output and PLL section for detailed description on capacitance values:
Hope this helps!
Honey
Thank you for your reply
Actually, I wanna use BGT24LTR11, so I need the information about BGT24LTR11.
Could U give me some information about BGT24LTR11 Loop filter?
Plus, is there difference betwwen BGT24LTR11 and BGT24MTR11?
Thank you sir.
Hello @iiillliili ,
Hope this helps!
Honey
