Deepa_V
50 likes received 250 replies posted 5 likes given
Hi @huzaifa666 ,
For generating the range-doppler map, you'll need to manipulate the data that you get from the Matlab to provide the range and velocity information. You can use the algorithm in range_doppler.c file available in IFX_P2G-HW-SW_V1.0.4\Firmware_Software\DAVE project\P2G_FMCW\Algorithm\src as reference and write it accordingly in MatLab.
Hope this helps !
Deepa
Deepa_V
Hi @huzaifa666 ,
Hope this helps !
Deepa
