Dear Sir,
We would like to set “Frame Interval” to 50ms in our application, can it be set? thanks.
Hi @User19535,
The Frame Interval [ms] edit box, you see on the Radar GUI, defines the time interval used for refreshing GUI plots. It's NOT a data acquisition frame interval.
For the Demo BGT60LTR11AIP this feature in the Radar GUI is meaningless, since we do not have a frame concept here, we do only an equidistant sampling, based on the number of samples.
Montassar.
Hello @User19535 ,
The frame intervals cannot be changed for BGT60LTR11AIP in the RADAR GUI.
Honey
Dear Sir,
if not using GUI. can it be changed? How ? thanks.
Hello @User19535 ,
The frame intervals cannot be changed for BGT60LTR11AIP in the RADAR GUI or otherwise.
Since for your application the frame intervals are to be changed, I would suggest you to go through our products based on 24GHz and also BGT60TR13C, where the firmware is frame based and you can vary frame interval according to your application
Hope this is helpful
Honey
Hi @User19535,
Montassar.
