I am building an application that can detect presence of objects, firstly I want to build it with dev board as prototype, also I want to build a device as cheap as possible, so it is mandatory to detect presence or stationary of object. Kindly suggest me what is the best sensor I can use.
Thank you in advance!
Hello @leotrim ,
According to the application you are building we would suggest you to go through BGT60TR13C Radar sensor and the presence detection and sensing solution for detailed information on the sensor.
Honey
Hello @leotrim ,
Honey
Hello @leotrim ,
Hope the issue is solved at your end, closing the thread. For further information and support please create a new thread
Honey
