HR
10 sign-ins 5 sign-ins First like given
Gibt es fertiges Produkt (Prototype), die den BGT60TR13C zur Erfassung von Vital-Funktionen der Menschen nutzen.
Wenn ja, wie heißt das Produkt?
Welche Sample Codes des Radar Development Kit sind zur Erfassung von Vital-Funktionen der Menschen geeignet?
Deepa_V
50 likes received 250 replies posted 5 likes given
Hi @HR ,
There isn't a finished product available for Vital sensing but you can surely use the sample codes in the latest version of the RDK (Radar Development Kit) for developing the same at your end.
You can also refer the following thread which would help you in developing the application at your end: https://community.infineon.com/t5/Radar-sensor/higher-sampling-rate-capturing-of-BGT60TR13C/m-p/3535... .
Hope this helps !
Deepa
Deepa_V
Hi @HR ,
Hope this helps !
Deepa
HR
Hi Deepa,
vielen Dank für die Infos.
Hat die Erfassung der Vital-Funktionen (z.B. Herzschlag) von Menschen grundsätzlich mit einem Prototypen im Entwicklungslabor funktioniert?
Wenn ja, wird es Sample Codes dazu demnächst im Radar Development Kit geben?
Viele Grüße
Horst
Deepa_V
Hi @HR,
Yes, this worked in principle but still requires some tuning and testing before the release. It might be released with one of the future releases RDK once it reaches optimal performance.
Deepa
HR
Hi Deepa,
could I get the code that works in principle already now to optimize it myself.
Horst
Deepa_V
Hi @HR ,
We will get back to you on this through private channel.
Deepa
