ronnief1
25 sign-ins 10 questions asked 10 replies posted
I have the BGT60TR13C set up on a tripod about 1.5m high, faced forward, in portrait orientation (i.e. the radar chip is on top). I know the azimuth angle is from -40 to 40 degrees. I was wondering what the elevation angle is? I'm trying to detect falls and other human activities.
Siddharth_H
100 solutions authored 50 likes received First question asked
Hi @ronnief1 ,
Set max angle is regarding the azimuth angle in range_angle_map.py.
Thankyou, Siddharth
Siddharth_H
Hi @ronnief1 ,
BGT60TR13C  has -45° to +45° azimuth FoV and -45° to +45° elevation FoV
You can find this info in section 3.2 of the AN600: BGT60TR13C Shield Application Note
Thankyou, Siddharth
ronnief1
Thank you. I know in the range_angle_map.py you can set the max angle degrees. is that regarding azimuth or elevation?
Siddharth_H
Hi @ronnief1 ,
Thankyou, Siddharth
