Does Infineon radar have any application cases for gesture recognition that are easy to share?
Translation_Bot
Dears:
I have a few questions about RADAR SENSOR:
a. Does Infineon radar have application cases for gesture recognition that are easy to share?
b . In the 60G radar scheme, in the BGT60LTR11AIP data sheet, in the SPI chapter, there is no description of SPI registers. Can you provide complete instructions?
C. The source code contains the library file libAMS_lib.a. The source code is missing, and contains key functions:
void algo_advanced_motion_sensing_init (& algo_advanced_motion_sensing);
unsigned int algo_advanced_motion_sensing_run (algo_ams_t *instance);
The library was placed in Keil's compilation environment, and the library was not recognized.
.a is a link library used by dev-C++, and the compiler for dev-C++ is gcc. Can you provide the source code for libAMS_lib.a?
Best Sides
Sam Zhang
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%9B%B7%E8%BE%BE%E4%BC%A0%E6%84%9F%E5%99%A8/%E8%AF%B7%E9%97%AEInfineon-%E9%9B%B7%E8%BE%BE%E6%98%AF%E5%90%A6%E6%9C%89%E6%89%8B%E5%8A%BF%E8%AF%86%E5%88%AB%E6%96%B9%E9%9D%A2%E7%9A%84%E5%BA%94%E7%94%A8%E6%A1%88%E4%BE%8B%E6%96%B9%E4%BE%BF%E5%88%86%E4%BA%AB/td-p/667963
Translation_Bot
hi rut_samzhang,
a Gesture recognition case sharing:
  1. Human-computer interaction: BGT60TR13C can recognize gestures and track motion. Achieve a detection range of 1 to 2 meters, and detect and track user gestures to control various devices.
  2. Smart home: The 60GHz Radar controls lights, curtains, temperature, and more without directly touching the device. It supports a detection range from a few centimeters to a few meters, and can recognize a variety of gestures.
b BGT60LTR11AIP data sheet, see chapter 3 of the user manual for an introduction to SPI registers:
https://www.infineon.com/dgdl/Infineon-AN625_User's_Guide_to_BGT60LTR11AIP-ApplicationNotes-v01_70-E...
c does not currently provide the source code for libAMS_lib.a. Please check if the Keil compiler is compatible with the compiler used in the library file? Is the library path in the Keil compilation environment set correctly? Try converting the library files into a format that the Keil compiler recognizes. A specific tool or conversion program is required. Converting the library file format may cause unpredictable issues; please back up the original library file before converting.
BR
Yaran
smartconx_target@Q!w2e3r4t5y6u7i8o9p0||/t5/%E9%9B%B7%E8%BE%BE%E4%BC%A0%E6%84%9F%E5%99%A8/%E8%AF%B7%E9%97%AEInfineon-%E9%9B%B7%E8%BE%BE%E6%98%AF%E5%90%A6%E6%9C%89%E6%89%8B%E5%8A%BF%E8%AF%86%E5%88%AB%E6%96%B9%E9%9D%A2%E7%9A%84%E5%BA%94%E7%94%A8%E6%A1%88%E4%BE%8B%E6%96%B9%E4%BE%BF%E5%88%86%E4%BA%AB/m-p/668039
Translation_Bot
hi rut_samzhang,
BR
Yaran
