Dear friends,i want to realize the funtion of people counting at a place with 60GHZ mmwave sensor,but i can't find any information about it at this website.
Thank you very much for reply!
Hi @Anna-xuan ,
It wouldn't have the realized code or absolute steps for that matter but it will surely guide you on the implementation as the concept is somewhat the same. You can implement for people counting in the same way using the available codes in the Radar Development Kit (RDK). For the initial implementation, you'll be required to work with the Range FFT or Segmentation algorithms which can enable detection and is already available in the RDK.
Deepa
Hi @Anna-xuan ,
There aren't documents available specifically on People counting but there are documents available for smart entrance counter which you can possibly take as a reference to develop your algorithm for people counting.
Please refer : https://www.infineon.com/cms/en/product/promopages/smart_entrance_counter_solution/ , https://www.infineon.com/dgdl/Infineon-EntranceCounterSolution_with_60GHzRadar-ProductBrief-v01_00-E... for smart entrance counter solutions.
Hope this helps !
Deepa
Thank you,Deepa V
Does it have absolute step or realized code?
Hi @Anna-xuan ,
Deepa
Hi,Deepa V
Thank you for your reply.I've got some inspirarion under your guidance.Thank you so much!
Yours,
Anna Xuan
