Anna-xuan
25 sign-ins 10 replies posted First like received
Dear friends,i  want to realize the funtion of  people counting  at a  place  with 60GHZ mmwave sensor,but i can't find any information about  it at this website.
Thank you very much  for  reply!
Deepa_V
First comment on KBA 50 likes received 250 replies posted
Hi @Anna-xuan ,
It wouldn't have the realized code or absolute steps for that matter but it will surely guide you on the implementation as the concept is somewhat the same. You can implement for people counting in the same way using the available codes in the Radar Development Kit (RDK).  For the initial implementation, you'll be required to work with the Range FFT or Segmentation algorithms which can enable detection and is already available in the RDK.
Deepa
Deepa_V
Hi @Anna-xuan ,
There aren't documents available specifically on People counting but there are documents available for smart entrance counter which you can possibly take as a reference to develop your algorithm for people counting.
Please refer :   https://www.infineon.com/cms/en/product/promopages/smart_entrance_counter_solution/ , https://www.infineon.com/dgdl/Infineon-EntranceCounterSolution_with_60GHzRadar-ProductBrief-v01_00-E... for smart entrance counter solutions.
Hope this helps !
Deepa
Thank you,Deepa  V
Does  it have  absolute  step  or  realized  code?
Deepa_V
Hi @Anna-xuan ,
Deepa
Hi,Deepa V
Thank  you for your reply.I've got some inspirarion under your guidance.Thank you so much!
Yours,
Anna Xuan
