h_nakamura
Distributor - NEXTY (Japan)
10 solutions authored 50 questions asked First like received
I'm following "2 Getting started guide of AN615" and trying to connect using the Radar GUI tool.
But the connection fails with an error. (AN615 page 10 of 32 STEP 😎
(Tried Radar GUI versions 2.8.2.202205190911 and 2.8.1.202110151545)
Please let me konw solution.
Nakamura
You're welcome.
Right ! It's under IFX_D2GL-HW-SW_V1.0.0\Firmware_Software\DAVE project folder.
Montassar.
Montassar-BR
5 questions asked 250 sign-ins 25 likes received
Hi @h_nakamura,
Radar GUI v2.8.2 should be the right one. Have you flashed the D2GL_SC_FMCW.hex Firmware binary image?
Could you please share a picture of your setup? Which on-board USB port are you connecting?
Cheers,
Montassar.
h_nakamura
Hi Montassar,
Thanks for your reply.
Regarding FW flash, it did but the fail didn't solve.
I attached the picture.
Nakamura
Hi @h_nakamura,
Please do the following:
  • Click on "Disconnect" button.
  • Disable the "Auto Connect"
  • Go to "Windows", "Show Views", "Logging"
  • Set logging to "FINEST", then click on "Clear" button, then close the "Logging" window.
  • Click on "Connect" button
  • If it is still showing the same error, please go to the logging and share the Log content
Hope that helps.
Cheers,
Montassar.
h_nakamura
Hello Montassar,
I did it folowing your suggestion but the same error occurred as below.
Nakamura
Hi @h_nakamura,
please share the full log, so that we can go through it.
Cheers,
Montassar.
Siddharth_H
100 solutions authored 50 likes received First question asked
Hello @h_nakamura .
Sorry for the delayed response, can you please confirm if you are selecting the correct comport? You can also attach a snip of your Ports in device manager.
Thank you,
Siddharth.
h_nakamura
I don't think there is a problem with the COM Port when connecting to the GUI, but what do you think?
Nakamura
Hi @h_nakamura ,
Can you once check Radar GUI v2.6.0 with it's firmware and let me know if it works. If not, I will get you more help.
Thank you,
Siddharth.
h_nakamura
I wrote and confirmed Radar GUI v2.6.0 and its firmware, but
It doesn't work with the same error.
Nakamura
Hi @h_nakamura,
Have you made any hardware modifications to the DEMO DISTANCE2GOL board?
Would you please try using a different USB cable to connect the board to the PC?
Radar GUI v2.8.2 should be the right tool version to use.
Cheers,
Montassar.
h_nakamura
Sorry for late reply. I'm out of the office by today. I'll feedback it next week.
Nakamura
h_nakamura
Hello Montassar,
I think that "Import DAVE projects and debug" doesn't work well. Please let me know the steps after running DAVE IDE.
Nakamura
Hi @h_nakamura,
Please ensure to follow the steps under 3.1 section of the XENSIV™ 24GHz radar tools and development environment UM.
Montassar.
h_nakamura
Hello Montassar,
Thanks for your prompt reply. Please let me know where is the DAVE projects list. Is it in "IFX_D2GL-HW-SW_V1.0.0" folder?
Nakamura
You're welcome.
Montassar.
