Connecting Sense2GoL Pulse Radar Demo to an Arduino/Raspberry Pi
inbar214
I am trying to connect my Sense2GoL Pulse Radar Demo to an Arduino or raspberry pi with this -https://www.infineon.com/dgdl/Infineon-AN605_Sense2GoL_Pulse_Demo_Board-ApplicationNotes-v01_00-EN.p...
My board version is 3.0 and it seems that the pinout and connections are different then what's explained in the link I attached. Is there an updated explanation for board version 3.0?
Thank you.
Deepa_V
50 likes received 250 replies posted 5 likes given
Hi @inbar214 ,
Thank you for pointing this out. We'll get this rectified. Meanwhile, You can refer the diagram on page 14 of this Application Note :  https://www.infineon.com/dgdl/Infineon-AN602_Radar_Baseboard_MCU4-ApplicationNotes-v02_10-EN.pdf?fil... .
Hope this helps !
Thanks and Best Regards,
Deepa
Deepa_V
Hi @inbar214 ,
No, the pinout and the connections happen to be the same for v3.0 of the board as well as is shown in the application note. Do explain your issue by sharing the images of your board if possible !
Deepa
inbar214
Hi @Deepa_V ,
I am attaching a photo of my board and of the schematic of the board from the link I attached in the previous response. You can see the marks on the board that indicate P2-P7 are on different places on the board, and the explanation references to these marks.
Thank you!
Deepa_V
Hi @inbar214 ,
Hope this helps !
Deepa
