Hello to every one,
I want to ask you a question. I want to use BGT24MTR11 or other models in a project. But I haven't decided on the MCU yet. I've often seen this MMIC used with the XMC processor. To what extent will I have compatibility problems if I use it with stm32 or other brand processors?
Thank you.
Regards.
XMC
Hello @AEnes,
The BGT24MTR11 is used with XMC4200 32-bit Arm® Cortex®-M4 MCU to perform the radar signal processing.
The XMC4200 takes care of communication with all the subsystems on the radar module, enables data
acquisition, performs the complete radar signal processing (including sampling and FFT) and communicates the
results via its UART or USB interface to an external device. So, any controller which is capable of performing the above mentioned, will work.
Pugitha.
Hello @AEnes,
Pugitha.
