Hi everyone,
I have a hypothetical situation: there are two objects in the same state (range & velocity), but they are different in angle. Configuration of 60GHz radar sensor (bgt60tr13c) with two receivers (Azimuth), by using capon algorithm, can we distinguish them?
Minh
Hello @85258 ,
You got it theoretically right!
As BGT60R13C has L-shaped antennas for receiving part and for higher angular resolution, more than two receiver antennas would require in azimuth and elevation angle to distinguish such targets. Thus, it would not be possible with BGT60TR13C.
Honey
Hello @85258 ,
Angle capon can be used to distinguish between two objects at different angles. Please refer to the documentation for further details located at file /Radar%20Development%20Kit/3.2.1.202205180921/application/RDK-TOOLS-SW/RDK-TOOLS-SW/SDK/doc/html/index.html/ after installing the Radar Development Kit
Hope this helps
Best Regards
Honey
Hi @Honey_D,
Thanks for your information. But I am confused about that.
case1: Let says we have some snapshots ( 5 snapshots per Rx, like the default setting in FW) and do the capon algorithm. With these snapshots, we can detect one object (dominant in power). In other snapshots, we detect another one(dominant in power). So, we can distinguish them. If your idea is like that, it's ok!
case2: we only have 5 snapshots, can we distinguish two objects? I think we need more than two receivers (at least 3 receivers) per azimuth or elevation to distinguish them. Did I get it wrong theoretically? max(target in same range) < (number of Rx - 1).
Best Regards
Minh
Hello @85258 ,
Honey
