Cannot connect to Radar GUI after connecting to XMC Flasher
User21577
First question asked
Im new to this forum and have an issue, please help.
I have just installed the SENSE2GOL PULS and followed the steps to connect to Radar GUI. No issues.
Then I changed the USB to debug and programmed pulsed doppler in XMC Flasher using SEGGER
Now when I disconnect the radar, I get a red flashing LED light.
When I reconnect to default USB, I also get a flashing red LED light. Then Radar GUI cannot connect.
Honzo
Michael_Kiessli
First like given 5 replies posted 5 sign-ins
A fast blinking LED is an indication that the RF-shield is not connected. Then the RadarGUI could also not connect.
So connecting the RF-Shield should help.
In case the the RF-shield is connected properly, and the LED is still blinking the EEPROM on the RF-Shield was erased or is not correctly programmed.
For that case, please provide your contact details to support to provide you detailed instructions.
Best Regards
Michael
Michael_Kiessli
Best Regards
Michael
