Is it possible to use the Sensing GUI if we develop new board based on the HW design of the Radar baseboard MCU7 but the new board doesn't mounted the MCU ATSMS70Q21?
Dose it check to match the CHIPID_CIDR or CHIPID_EXID of Microchip ATSAMS70Q21 mounted on the MCU7 when the Sensing GUI connects the Radar baseboard MCU7?
Is it possible to use the Sensing GUI if the MCU ID doesn't match the ATSAMS70Q21 ID? Is there a way to use the Sensing GUI if the ID doesn’t match?
The memory size of ATSAMS70Q21 is 2048B, but is it possible to use the FW of RadarBaseboard MCU7_v116 even with a 1024kB MCU(ex. SAMS70Q20)?
N.N
Radar Sensor
Hello @h_nakamura
Sensing GUI will not be affected by the microcontroller used on the sensor board as long as the board supports either Commlib or Strata protocol the GUI will support the board.
In order to use a different chip variant, the project has to be adapted to use the right defines.
Honey
Hello @h_nakamura ,
Can you please confirm which Sensing GUI and the RADAR sensor you are using to develop the project ?
Honey
Thanks for your prompt reply and sorry to forgetting those information.
MMIC is the BGT60ATR24C and GUI is "IFX_Radar_BGT60ATR24C_ES_Advance_V1.5\GUI".
H.N
Hello @h_nakamura
Honey
