h_nakamura
Distributor - NEXTY (Japan)
10 solutions authored 50 questions asked First like received
Hello, I have some questions regarding "Psense" in the Figure 2 BGT60TR13C Bare Die Block Diagram and "if_mix1-3"/"ifx_mix1-3" in Figure 72.
Q1. Is "Psense" the monitor level of PPD_PA?
Q2. What is "SADC:CH3 (pd_out)" and "SADC:CH4 (pd_outx)"?
Q3. I'm going to monitor Pout regularly during segmentation sensing to ensure MMIC performance, is that correct?
Q4. I think that if_mix1-3/Irx_mix1-3 are IF I/Q  data but please let me know usage of them. Are they for confirmation of the RF receive operation?
Honey_D
5 comments on blog 50 likes received 250 replies posted
Hello @h_nakamura ,
Psense is a power detected at the output of power amplifier at transmitter section.
The pd_out is the peak detector level at the output of the TX, while the pd_outx is the reference with the information of sensor thermal drift. Please refer to the footnote 4) on datasheet page 86.
The "if" and "ifx" are the differential signal pairs from the mixer.
I hope this helps
Honey
Honey_D
Hi @h_nakamura,
The Figure 72 which you mentioned is not there in the datasheet.
I am referring to datasheet https://www.infineon.com/dgdl/Infineon-BGT60TR13CDataSheet-DataSheet-v01_00-EN.pdf?fileId=8ac78c8c7d...
Can you please share the datasheet that you are referring to?
Honey Dhandhukia
h_nakamura
Hello, thanks for you reply. I'm referring the "Restricted under NDA" version(113 pages in total).
Nakamura
Honey_D
Hello @h_nakamura ,
I hope this helps
Honey
