geologic
Hi all
I want to count people on a building entrance with the following use case:
- in-out count
- sensor on the side of the path
- trigger 2 GPIO pins to send in-out counts to a external microcontroller
- low power / battery operated
At local vendors i saw BGT60TR13C sensor available on 2 kits, DEMOBGT60TR13CTOBO1 and KITCSKBGT60TR13CTOBO1. Can you advise what the best option for a prototype? I saw some examples for entrance counter (https://github.com/Infineon/mtb-example-sensors-radar-entrancecounter) but it is only for CYSBSYSKIT-DEV-01 and KIT-BGT60TR13C-EMBEDD kits, which i cannot find available.
Thanks @Honey_D for your reply.
But i'm confused, you suggest KIT CSK BGT60TR13C but the 2nd, 3rd and 4th links are for EMBEDD kit witch i cannot find available for purchase.
Can i use the code examples from EMBEDD kit on KIT CSK BGT60TR13C?
Honey_D
5 comments on blog 50 likes received 250 replies posted
Hello @geologic ,
The product is listed as a partner board and to procure the same please refer:https://www.arrow.com/en/products/mm5d91e00/jorjin-technologies
Honey
