shuchi
25 sign-ins 5 replies posted 5 likes given
import numpy as np
from ifxAvian import Avian
import csv
print("Radar SDK Version: " + Avian.get_version())
with Avian.Device() as device:
    # set device config
    config = device.get_config_defaults()
    device.set_config(config)
    # A loop for fetching a finite number of frames comes next..
    with open('radar.csv', 'w+') as file:
        f_radar= csv.writer(file)
        for frame_number in range(10):
            frame = device.get_next_frame()
            num_rx = np.shape(frame)[0]
            print (np.shape(frame))
    ## initialize empty list to hold reshaped slices
        reshaped_slices= []
    #loop through each slice along the first index
        for i in range(frame.shape[0]):
            current_slice= frame[i, :, :]
            print(current_slice)
        # Do some processing with the obtained frame.
        # In this example we just dump it into the console
        print ("Got frame " + format(frame_number) + ", num_antennas={}".format(num_rx))
        for iAnt in range(num_rx):
            mat = frame[0, :, :]
            print("Antenna", iAnt, "\n", mat)
Thank you for your available Python wrapper example code. I am able to get all the frame data. However, I wish to write each antenna data into .csv file and analyse for which i modified a little in the code but not able to see any data in the file that i am saving. can you kindly help in this? Thnaks again.
import numpy as np
import csv
# open device: The device will be closed at the end of the block. Instead of
# the with-block you can also use:
#   device = Device()
# However, the with block gives you better control when the device is closed.
    # set device config
        reshaped_slices= []
Siddharth_H
100 solutions authored 50 likes received First question asked
Hey Suchi!
Looks like you had posted the thread in a different forum page, so we missed it. Apologies for that.
So, Below is a little piece of Python code that you can use to save the data to CSV file.
import numpy as np
import csv
import pandas as pd
        pd.DataFrame(mat).to_csv('rawData.csv')
Hope this helps : )
Thank you,
Siddharth.
Siddharth_H
Hey Suchi!
import numpy as np
import csv
import pandas as pd
Hope this helps : )
Thank you,
Siddharth.
Thank you Siddharth 🙂
