BGT60TR13C: Max Speed
AMEE23
5 replies posted 10 sign-ins First like given
I am wondering how max speed is calculated. I tried looking through SDK but it seems the value is hard-coded. I also tried looking at some documentation but that did not help. I thought the max speed would be
Max_speed = lambda/(2*Tc), but I get wrong values.
I am using the "chirp time" for Tc.
When I try "Chirp Repetition Time" the values seem to make more sense but are still off. GUI will show -12.3 to 12.3, but I calculate -14 to 14.
I thought "chirp repetition time: would make more sense because it would be the total chirp time, but I am assuming that it is t_prt. I included image below.
Any help is greatly appreciated. Thank you.
- amee
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @AMEE23,
wavelength (lambda) = speed of light (m/s)/ center frequency (Hz)
center frequency = (lower frequency + higher frequency)/2
Pugitha
Pugitha_N
Hello @AMEE23,
Max speed = lambda / 4*PRT(pulse repetition time). That is how it is computed in SDK. Please refer to Introduction to radar section in Radar SDK Documentation. Document is available in radar_sdk directory of RDK package.
Yes, it is tprt from the chirp diagram.
Pugitha.
@Pugitha_N  thank you for taking the time to reply. Can you please specify if lambda is the wavelength of the lower frequency? Thank you so much for taking the time to respond.
-amee
Pugitha_N
Hello @AMEE23,
Pugitha
