BGT60TR13C Firmware
waet
First question asked Welcome!
Hi!
I would like to add some signal processing to the MCU of the Demo BGT60TR13C board, using the existing firmware for said board. Chapter 4.4 of the AN599: RadarBaseboard MCU ApplicationNotes states that "The firmware is delivered as a project for the Atmel Studio 7 IDE".
Where can I get this firmware?
Montassar-BR
5 questions asked 250 sign-ins 25 likes received
Hi waet,
Please start by downloading the "Radar Development Kit" from "Infineon Developer Center", then download the RDK-TOOLS-SW.zip file. The Radar Baseboard MCU7 FW is available from the RDK-TOOLS-SW.zip under  file \Firmware\RadarBaseboardMCU7-Sources_v2.4.0.zip.  Please follow the instructions under the README.txt file to compile the firmware project.
Montassar.
Montassar-BR
Hi waet,
Montassar.
Yes is also access to the different problems in signal processing in the MCU. But on google.com I saw the best solution to these problems and created a nice setup
andrew18391
First reply posted Welcome!
This application is used by the firmware to communicate properly and it is a project for Atmel. There is a demo on https://www.assignmenthelper.com.au/financial-assignment-help/ if you are trying to add signal processing to another setup.
jackrobin00
There is a major problem in connecting signal processing to the MCU. But I have a solution to this problem because Downloadtimecalculator is much helpful for this setup.
