Laldin
So I am currently writing firmware to interface Traveo board (using SDL) with the BGT60TR13C radar. However I am unable to detect the sensor, as the chip id returned is not correct.
According to dataset CHIP ID is :
This is my code to read the chip_id :
uint32_t chipid;
if (XENSIV_BGT60TRXX_STATUS_OK == status)
status = xensiv_bgt60trxx_get_reg(dev, XENSIV_BGT60TRXX_REG_CHIP_ID, &chipid);
xensiv_bgt60trxx_device_t device_type = detect_device_type(chipid);
if (device_type != XENSIV_DEVICE_UNKNOWN)
dev->type = &bgt60trxx_types[device_type];
else
dev->type = NULL;
status = XENSIV_BGT60TRXX_STATUS_DEV_ERROR;
return status;
This chipid being returned is
This results in the device not being detected correctly.
Also, the CHIP_ID changes for every build.
Kindly suggest how this can be solved. Thanks!
Pugitha_N
100 solutions authored 250 sign-ins 50 solutions authored
Hello @Laldin,
Would you be able to read the Digital ID and RF ID and update me on their respective values?
If the values for both parameters return as 3, then it is an indication that you are connected to BGT60TR13C.
Pugitha
Pugitha_N
Hello @Laldin,
Can you provide me with information on the value assigned to XENSIV_BGT60TRXX_REG_CHIP_ID?
Pugitha
Laldin
Hi Pugitha
Here it is defined as a macro
#define XENSIV_BGT60TRXX_REG_CHIP_ID                (0x02U) /*!< CHIP_ID: addr */
Pugitha_N
Hello @Laldin,
Pugitha
Laldin
Hi Pugitha,
These are the value for the parameters. Also these values changes for each run.
Laldin
Pugitha_N
Hello @Laldin,
Can you kindly provide us with the file for your program?
Pugitha
