- Email to a Friend
Dear sir
I have a questions description below
I follow Infineon-D2G_Application_Note_AN543_v1.5-ApplicationNotes-v01_05-EN.pdf TX path simulation
the slides in the annex pleases reviewed my sildes questions and give me your suggests
thanks
- Email to a Friend
Hi @scottho ,
Ideally, the transmitter side frequency should be 24GHz - 24.25 GHz with 250 Hz of bandwidth. And as for the layout files, all the available files can be found in C:\IFX_D2G-HW-SW_V2.0.2\Hardware. Please note that Distance2Go happens to be a discontinued board as per https://community.infineon.com/t5/Radar-sensor/Discontinued-Products-XENSIV-Radar-mmWave-24GHz-DEMO-... and is no longer supported.
Apologies for the inconvenience caused !
Deepa
- Email to a Friend
Hi @scottho ,
Deepa
