HS1234
5 sign-ins 5 replies posted First reply posted
I want the IC to work with the PLL without using the PTAT function.
In that case, please tell me how to deal with unused terminal pins (open, short to GND).
・VCC_PTAT(16pin): GND short
・V_PTAT(15pin):open?
Siddharth_H
100 solutions authored 50 likes received First question asked
Hello @HS1234 ,
Right, you can do the following. V_PTAT can be left open as it is usually input for the MCU.
  • VCC_PTAT(16 pin): GND
  • V_PTAT(15 pin): OPEN
Thank you,
Siddharth.
Siddharth_H
Hello @HS1234 ,
Thank you,
Siddharth.
Dear Siddharth
Thank you for your supports.
I understand.
Best regards.
Windows 10 版のメール<>から送信
