The customer is designing a bicycle radar light product. The reference is the Distance2GoL circuit design. IFI waveform does not have pulse waveform like EVM, it is always high level. As shown in the figure((Yellow VTUNE, Blue IFI) 1: Blue IFI is not powered down like the development board), the measurement is done on the front end of the op-amp. What is the reason for this?
Hello @brentcao ,
Can you please elaborate more on the problem you are facing for our better understanding, and also point the circuit design you are referring to for your application?
We are going through the question you asked, meanwhile you may also go through other potential product pages and application notes mentioned below for your better understanding: https://www.infineon.com/cms/en/product/evaluation-boards/kit_iot_xensiv_light/, https://www.infineon.com/cms/en/product/evaluation-boards/kit_smart_downlight_02/, https://www.infineon.com/dgdl/Infineon-IoT_LightingPlatform-ApplicationNotes-v01_02-EN.pdf?fileId=55... and https://www.infineon.com/cms/en/applications/industrial/led-lighting/connected-and-smart-lighting/
Hope this helps!
Honey
Hello @brentcao ,
We are closing the thread due to inactivity, please create a new one for further information
Honey
