Hi everyone
I would like to use the BGT24ATR11 to reduce current consumption as much as possible.
The LO terminal will not be used this time
Please comment our questions below.
■ On page 11 of the data sheet, when SPI-Bit 4 = High, the current consumption is Max 190mA.
Could you tell me how much current is consumed when SPI-Bit 4 = Low?
■If the 25-pin ANA pin and 28-pin LO pin are not used, is it okay to leave them open? Could you let me know if pin processing is necessary?
The Single-Ended LO pattern is listed on page 21. Is it a must to have this pattern?
■SPI Bits 0 to 3 seem to set the transmission power of the RF IC, but how much can the transmission power be adjusted by combining High and Low?
Yang
Radar Sensor
Hello @YoJa_3107936 ,
Apologies for the delay in response
On page 11 of the data sheet, when SPI-Bit 4 = High, the current consumption is Max 190mA. Could you tell me how much current is consumed when SPI-Bit 4 = Low? |
This is decreasing the gain of LO buffer. The difference in current consumption could be round about 5mA.
If the 25-pin ANA pin and 28-pin LO pin are not used, is it okay to leave them open? Could you let me know if pin processing is necessary? The Single-Ended LO pattern is listed on page 21. Is it a must to have this pattern? |
Yes, they can be open, if they are not used.
This pattern is recommended as matching circuit for this pin to 50ohm microstrip line only with given/recommended stack-up in the datasheet. If this pin is not used, the landing pad of the package would be enough. Pattern is not needed in that case.
SPI Bits 0 to 3 seem to set the transmission power of the RF IC, but how much can the transmission power be adjusted by combining High and Low? |
Please refer to the parameter ”TX output power adjustable range” on the table 6 in the datasheet.
Hope this helps!
Honey
We are having an internal discussion with the team regarding the same. Will reply as soon as possible.
Honey
Hi Honey
Thank you for your help!
When can you answer the above questions?
Yang
Hope this helps!
Honey
