Radar sensor Forum Discussions
shoko_s
Level 4
Level 4
25 sign-ins 25 replies posted 10 sign-ins
I have a question about BGT60TR13C radar.
Do you have any reference documents or the example programs to display Angle vs. Velocity heat map?
Please advise.
Thanks, Shoko
HoneyDhandhukia
25 likes received First comment on blog First question asked
Hello @shoko_s ,
All the algorithms supported by RDK are explained in documentation radar_sdk/doc/html/pg_radarsdk_algorithms.html
Apart from these, you will need take these as reference and develop your algorithm.
Hope this helps!
Honey
HoneyDhandhukia
Hello @shoko_s ,
Please refer to the python files DBF and range-angle-map for plotting the heat maps you are looking for located at radar_sdk\apps\py\examples. You can refer these files to plot the angle vs velocity heat maps. Please refer to https://community.infineon.com/t5/Radar-sensor/Radar-Data-Cube/td-p/384002 and follow the steps described to excute the python files
Hope this helps!
Honey
shoko_s
Level 4
Level 4
Hello Honey,
Thank you for your reply.
I have already refered DBF and range-angle-map but I don't know to compute Doppler-Angle map.
Should I have to compute the equivalent of "beam_range_energy"?
Thank you, Shoko
HoneyDhandhukia
Hello @shoko_s ,
Please refer to the sdk documentation (/radar_sdk/doc/html/pg_rdk_python.html#sct_rdk_python_algo), which describes on How to write an application using python wrapper.
Hope that helps!
Honey
shoko_s
Level 4
Level 4
Hello Honey,
Thank you for your information.
I'd like to know the algorithm to make Doppler-Angle map, but it is not described on the programs of radar-SDK.
Could you please let me know it If you know.
Best regards, Shoko
HoneyDhandhukia
Hello @shoko_s ,
Hope this helps!
Honey
shoko_s
Level 4
Level 4
Hello Honey,
Regards, Shoko
