Radar sensor Forum Discussions
shoko_s
Level 4
Level 4
25 sign-ins 25 replies posted 10 sign-ins
I have a question about "range-angle-map.py" of Radar-SDK's example.
It seems that the program of "range-angle-map.py" includes the element of DBM.
However, "range-angle-map.py" does not display 3D range-angle heat map.
Could you tell me why the element of DBM is included in "range-angle-map.py"?
Please advise.
Best regards, Shoko
Siddharth
10 solutions authored 10 likes given 25 replies posted
Hey @shoko_s
In rx_mask, Each antenna is assigned to a separate bit starting from LSB.
For example,
  • rx-mask=5: 5=101, so RX1 and RX3 are activated
  • rx-mask=7: 7=111, so RX1,RX2 and RX3 are activated
  • rx-mask=1: 1=001, so RX1 is activated
Hope this helps, please go through the RDK documentation ->Data Structures to know functionalities of all ifxAvian functions.
Thankyou, Siddharth
Siddharth
Hi @shoko_s
Before answering, am assuming you meant to say DBF( Digital beam formation) and not DBM.
So, The range angle map is a derived properties of the DBF algorithm, so the range angle map uses some components of the DBF to process the range angle map. So the DBF.py is included in range-angle-map.py
Please refer the RDK documentation for better understanding how DBF works.
Thankyou
Siddharth
shoko_s
Level 4
Level 4
Hello Siddharth,
Thank you for your response. I'm sorry, It was a typing mistake.
I understand that why the element of DBF is included in "range-angle-map.py".
By the way, I have some questions about the program of  "DBF.py".
1) Please let me know why nothing is defined for num_antennas.
2) Please let me know why 27 is defined for num_beams.
Please advise.
Regards, Shoko
Siddharth
Hi @shoko_s
1) In the "range-angle-map.py", The num_antennas is taking the value from num_rx_antenna  when the dbf object is created.
num_rx_antenna  gets it's value from config  parameters
Look at this line for understanding- num_rx_antennas = num_rx_antennas_from_config(config)
The flow goes this way:
config.rx_mask ➡️ num_rx_antennas_from_config(config) ➡️ num_rx_antennas ➡️ num_antennas
2) num_beams equaling 27 is just a user defined value, you can try out any values for it. It just defines how many beams the FOV should be broken down into.
BR, Siddharth
shoko_s
Level 4
Level 4
Hello Siddharth,
Thank you for reply.
About 2), I understand.
About 1), I don't understand how number of antenna related to range-angle-mapping on the program.
Doesn't this program perform AngleFFT (further FFT to the Doppler FFT result of each antenna)?
Regard, Shoko
Siddharth
Hi @shoko_s
  • DBF is an algorithm which the other files like range-angle-map.py uses, DBF alone doesn't have any output. DBF is included in range-angle-map.py, where the value from rx_mask is derived by the DBF to calculate the number of antennas.
  • The range-angle-map.py code file is implicitly linking to DBF.py using the command 'from DBF import DBF' and 'dbf = DBF(num_rx_antennas, num_beams = num_beams, max_angle_degrees = max_angle_degrees)' would ensure that the value configured for the num_rx_antennas is linked to both.
Hopes this helps you, Do post a reply if you have question or if you find a solution.
Thankyou
Siddharth
shoko_s
Level 4
Level 4
Hello Siddharth,
Thanks for reply. Yes I already understand that DBF is an algorithm which the other files, and DBF alone doesn't have any output.
In the first place, I'd like to know- why nothing is defined for "num_antennas" in DBF.py, not "num_rx_antennas" in range-angle-map.py.
In the end... how many is the number of (virtual) RX antennas in DBF.py specifically?
Thank you, Shoko
Siddharth
Hi @shoko_s
I understand your confussion,
"num_antennas" and "num_rx_antennas" are the same.  When the object is created, value from  "num_rx_antennas" is copied to "num_antennas".  In range-angle-map.py the variable is named "num_rx_antennas" and in DBF.py the variable is named "num_antennas" but they both have the same value.
Hope this makes it clear.
Siddharth
shoko_s
Level 4
Level 4
Hello Siddharth,
Thank you for reply. I understand.
Please let me know the reason it get popcount for rx_mask and rx_mask is defined "5". Please advise.
Thanks in advance, Shoko
Siddharth
Hey @shoko_s
For example,
Thankyou, Siddharth
shoko_s
Level 4
Level 4
Hello Siddharth,
Thanks for reply. I understand the meaning of rx-mask=5 and popcount process.
Also I'll check the documentation about ifxAvian functions.
Thanks for your support. Shoko
