Nonlinear model for BAR90-02ELS diode
Tara_Y
First question asked Welcome!
Hi All,
I am trying to figure out the nonlinear model for the BAR90-02ELS diode. The H-Spice works fine for forward bias but not for reverse bias. Anyone has the parameters to make a Caverly model that works for the reverse bias as well. I am trying to simulate it in AWR and these are the parameters I would need.
Thank you
Is (Reverse Saturation Current)
IKnee (Knee parameter for the current dependent tau)
N (Ideality factor)
RLIM (minimum series resistance)
REPI (Epi leakage resistance)
CJ (Reverse Capacitance)
CPKG (Package Capacitance)
Tau (Storage time)
W (I region width in micrometers)
B (ratio of electron to hole mobility)
LBOND (bond wire inductance)
