How to decode the datecode for BFR181WH6327. base on datasheet is YM but the symbols shows "1=", unable to decode the "=".
Hi @ericinthesky,
Please note that 1,2..9,O,N,D are used to represent the 12 months.
Thanks and regards,
George
Hi @Gil,
Yes. You are right. The format for date code as per the datasheet is as seen below.
The symbol in the shared image is not expected. Could you please check the same with other samples?
Thanks and regards,
George
Hi George,
All parts had the same marking.
Gil
Hi George, could you help explain the datasheet example how to use 1 digit code to contain 12 months?
as the online girl reply to me the datasheet is only for ref, not the final result.
and the goods we bought from which original source is arrow has the also remaking too.
Hi George,
please advise if there are any changes done with the datecode decoding or changes on the marking
Hi @Gil,
The request is already forwarded to the responsible team.
I will reply as soon as I get an update.
I am really sorry for the delay.
Thanks and regards,
George
HI George,
Please advise if you have received feedback from your respective team regarding the issues.
Gil
Hi @Gil,
There is a good possibility that it can be an "8", which means the month is August.
Could you please also check with ordering document regarding the date code?
Thanks and regards,
George
Hi @ericinthesky,
Thanks and regards,
George
