The BGSA142GN12 SP4T switch data sheet shows a single RFC pin. However the PCB footprints for the switch show an RFC1 and RFC2 pin. How should these 2 pins be handled? should they be shorted together? should RFC2 be floating?
Thanks!
ispn:21262:1:0
l1:33:1:0
l2:1362:1:0
Hi Annemariez,
both RFC ports are those that connect to the same signal path and are internally connected.
On your PCB design, please connect those 2 ports as well to keep the symmetrie in the connection. Below you find a screenshot of the evaluation board of this device family.
with best regards
Mathias
Hi Annemariez,
with best regards
Mathias
