Hi @xiexm,
The S-parameter measurements available, for downloading, is already de-embedded.
The De-Embedding s-parameter is provided for reference, if the evaluation board measurement is done at your end.
Thanks and regards,
George
Hi @xiexm,
Supporting documentation for the S-parameters for the switch can be found in the following section in addition to the mentioned S-parameters.
https://www.infineon.com/cms/en/product/rf/rf-switches-spxt-dpxt/bgs14wma9/#!designsupport
I am currently looking in to the de-embedding performed at your end to understand the problem.
Thanks and regards,
George
Hi @xiexm,
Thanks and regards,
George
Hi George,
Understand. Thanks a lot. So I use the s parameters downloading for my simultion since has been de-embedded.
Michael Xie
