The BGS12P2L6 is specified to max +37 dBm output, 50MHz to 6 GHz frequency range.
It is given data for IL for 617 MHz to 5925 MHz.
Do you have data for the lower range 50MHz to 617 MHz?
Is +37 dBm max power valid for this range as well?
- BGS12P2L6
Hi @Harald,
Please note that the maximum RF input power is valid for complete operating frequency range of 50 MHz to 6 GHz as mentioned in the datasheet.
S-parameters for the switch is available in the below link for the entire operating frequency range.
Thanks and regards,
George
Hi @Harald,
Thanks and regards,
George
