I use the flash S34ML08G1 in 8 bits databus.
When i read from even sectors it works ok.
When i read from odd sectors if fails.
Readed values does not match with writen values.
The first 64 bytes are ok but the rest are not.
It seems that the flash lost the connection after 64 bytes and it puts the bus in high impedance.
I check the status register after writing and is ok.
Any idea?
Jesús Rubiralta
Hello Jesús Rubiralta,
I would like to know more details about this issue. Could you please let me know the steps that you follow to reproduce this issue?
Are you facing this issue with all of the S34ML08G1 that you tested?
Thanks and Regards,
Sudheesh
Hello Sudheesh,
This is my code:
SECSIZ is 2048 bytes.
ECF_ErrorCode writeSector(unsigned long sector, unsigned char *src){
int add = sector * (SECSIZ);
int ret;
GPIOB_MODER = 0x55555555; //Put databus port as output
WP_OFF; //Disable write protection
if((add & 0x1FFFF)==0)
eraseBlock(add);
CE_ON; //Select the device
sendCommand(0x80);
sendAdd(add);
int numbytes = SECSIZ;
while(numbytes){
WE_L; GPIOB_ODR = ((*(unsigned char*)origen++) & 0xff); WE_H;
numbytes--;
sendCommand(0x10);
while(!READY);
sendCommand(0x70);
RE_L; ret = GPIOB_IDR; RE_H;
CE_OFF; //Disable the device
WP_ON; //Enable write protection
return((ret & 1) == 0) ? ECFERR_SUCCESS : ECFERR_FAILED;
ECF_ErrorCode readSector(unsigned long sector, unsigned char *dest){
sendCommand(0x00);
sendAdd(add);
sendCommand(0x30);
while(!READY);
GPIOB_MODER = 0; //Put databus port as input
while (numbytes){
RE_L;
*(char*)destino++ = (GPIOB_IDR & 0xff); // !!!!! After 64 bytes the bus goes to hi impedance !!!!!!
RE_H;
numbytes--;
return(ECFERR_SUCCESS);
Many thanks
Jesús Rubiralta
Hello Sudheesh,
I am facing this issue with all of the S34ML08G1 that i have tested.
Jesús Rubiralta
I checked the program snippet that you provided. Could you please let me know the number of address bytes that you sent to our device using the function " sendAdd(add);". Is it 4 bytes or 5 bytes?
Thanks and Regards,
Sudheesh
