Feb 25, 2016
04:57 PM
Feb 25, 2016
04:57 PM
Note: Because SPI_1 (External Flash) and I2C (Bus used by sensors) share several of the same pins, you cannot boot from SPI Flash and use the sensors onboard the BCM92073X_LE_TAG4 kit (the kit will come up, but the sensors will not respond). To use the sensors, please boot from the onboard EEPROM instead.
Labels
TAG4
