GPIO INT#
 Hi, is it possible to use GPIO pin INT# as flag (setting its value by CyU3PGpioSetValue function)?
You can control this INT# signal from the GPIF II state machine.
If you select this signal as output then you can use DR_GPIO to drive this line from the GPIF II state machine.
If you want to use it as Inturrept signal itself then you can call INT_HOST action to assert.
Sai Krishna.
Sai Krishna.
 What is DR_GPIO? I can't find anything like it in SDK documentaion
 Oh, I see, DR_GPIO is action in GPIF Designer. SO there is no way to use GPIO INT in GpioSetValue function or something similar? Does it have gpioID?
Yes. DR_GPIO is also an action in the GPIF II Designer.
It does not have a GPIO ID to drive it using the API GpioSetValue.
Sai Krishna.
mcn
Nothing like replying to a 9 year old post, but I hope this works...
I understand using DR_GPIO to drive the INT# line as an output, but I don't understand how it can be used as an interrupt input. Is this possible?
If so, how do I poll the state of this line and/or setup an interrupt callback?
Thanks!
SampathS_11
Moderator 250 sign-ins 250 solutions authored 5 questions asked
Hello @mcn ,
We are extremely sorry that we may not be able to track a 9 year old post. If you may be kind enough to create a new question, referencing this question, it would be very helpful to us, to keep track of your question and our answers.
Sampath Selvaraj
