Pressure Sensors Forum Discussions
Kenta
I am working on the pressure sensor (DPS310) for my study.
The time resolution of the sensor is around 4Hz which I would like to develop.
Do you guys have any idea to develop the time resolution of the DPS310?
It is ok to  lose the accuracy a little bit after I fix the time resolution of the sensor.
GeorgeT
250 sign-ins 50 solutions authored 25 likes received
Hi @Kenta,
Could you please clarify whether you are referring to the measurement rate?
Thanks and regards,
George
Kenta
Yes, the time resolution here means the measurement rate which is now around 4 Hz which I want to develop.
Thank you.
GeorgeT
Hi @Kenta,
The measurement times are clearly mentioned in the datasheet. Please refer to the Table 16 of the datasheet (page-30) and use the same for measurement rate calculations.
Thanks and regards,
George
