Pressure Sensors Forum Discussions
__
GeorgeT
250 sign-ins 50 solutions authored 25 likes received
Hi @__,
Please note that the sensor has the operating pressure range till 1200 hPa.  The package dimensions and other specifications are also given in the product datasheet
Please verify if it matches you requirement.
Thanks and regards,
George
__
Thank you for the response.
However, I wanted to know if the sensor is capable of measuring pressure changes in a small environment like a balloon or a box.
GeorgeT
Hi @__,
Sorry for the delay in responding.
I do not find any problem in using DPS310 sensor for the requirement.
One point to be considered is that sensor hole should not be blocked at any time of measurement.
Thanks and regards,
George
