George_32bit
Hi! Where can I get board design file for zcu111 for PowIRCenter software?
Nishanth
100 solutions authored 10 likes given 100 replies posted
Hello @George_32bit ,
Thank you for contributing to the Infineon Community.
I have included the below link for all the details including the configuration files related to ZCU111 Evaluation board.
https://www.infineon.com/cms/en/product/promopages/xilinx-SoC-FPGA-power-reference-design/Xilinx_Zyn...
Nishanth
Xiangrui
500 replies posted 250 solutions authored 50 likes received
Thanks for posting.
We have noticed your request and will work for it.
BR,
Xiangrui
Nishanth
Nishanth
I can't find .pcd file for PowIRCenter at your link. could you attach this file in a message?
Nishanth
Hello @George_32bit.
.pcd files are the board design files that are used for the initial design in the PowIRCenter GUI.
However, if you want to burn the configuration into the NVM, .pcd files should be converted to the 3-column text file in .txt format.
The configuration files available in the link are directly in .txt format which can be used to do the programming on the part.
Kindly refer to page 37 - 24 File Format of the  PowIRCenter Installation and User Guide for more details.
Nishanth
