I am working with development kits TLE9015DQU_TRX_BRG, TLE9012_DTR_BMS2 AND AURIX TFT boards. Going through the manual, it states:
Select the *.hex file “Infineon_TLE9015DQU_TLE9012DQU_TC265.hex” stored on MyICP.
When I try to log into MyICP it says I don't have access. I have requested to support but had no response for nearly 2 weeks now 😞
Is there anywhere else I can find this file publicly?
I've sent some information via private message. Please contact me and we'll get your access straightened out.
Hi Scott, thank you. Have sent you an email.
Hi Scott,
I am also encountered this problem, would you kind enough to help me with that?
I've sent a private message with more information.
Hi Scott,
I've encountered the same issue. Do not have any way to find the .hex file through myICP.
Thanks for any tip that might help us.
Hi Scott,
