Dear Infineon
Recently, I brought two set of eva board, refxdpl821035W & refxdpl8221, and try to communicate with them using dp. gen 2.0 interface. But both of them need to use different dp. version, i.e dpifgen2rev1-12-0 hex for xdpl 8210 & dpifgen2rev2-5*-0 hex for xdpl 8221. Is it correct?
Besides, I always got the error message ' Aparam out of batch' while change the setting of xdpl 8221
Any suggestion?
HK
Hi @ckeeltd
Earlier you mentioned that you are facing Aparam out of batch Error but the screenshot you shared is different.
Please check the polarity of the programming connector and reconnect it. Still if the error persists Please refer to the attached documentshttps://www.infineon.com/dgdl/Infineon-dp%20Vision%20GUI-PB-v01_00-EN.pdf?fileId=5546d4624fb7fef2014...
The driver we are using here is a CP driver-based which will deliver the specified current and power rating.
Can you please tell us why do you want to change the output parameters?
For communication between XDPL8221 & UART ,Refer to the attached documents
Kanahaiya
