sammy
Distributor - Avnet(GC)
First reply posted 10 sign-ins 5 sign-ins
   I'm using TLE9262-3BQX, downloaded tool of config wizard for sbc,the configuration of VCC3 in register HW_CTRL bit 7 in toolbox is different from datasheet, which should i follow?
It is expected behavior, the marked registers below can be changed in the next "power on" only once it is set.
Meanwhile, I got feedback from the development team. The issue with GUI will be fixed in the next version.
Vishnu N
Vishnu_Nambrath
50 solutions authored 100 replies posted 5 likes given
Thanks for pointing out the issue.
We have raised an internal request for the same.
Meanwhile, Can you please measure VCC3 when you uncheck the box? Is it same output voltage as VCC1
Vishnu N
sammy
    Yes,Same as VCC1,Maybe the register mapping is right but description is wrong, and also VCC3 voltage configuration is valid for one time only after device power up.
Vishnu N
